1994 Chevy S-10 Coolant leak
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEVIN DICKERSON
My coolant was leaking about two weeks ago. I was told i needed a new water pump. After installing that, the leak stopped. Now its leaking again and i was wondering where it could be coming from.
Oct 15, 2008 at 9:29 AM
BLACKOP555
  • 10,386 POSTS
since replacing the pump fixed it, i woudl be checking the water pump out to make sure its that before replacign it again, you go with a top of the line part or a cheap one? check the hoses also.
Oct 3, 2020 at 4:17 AM
