1994 Chevy S-10 condensor
1994 CHEVROLET S-10
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROYCABANISS
how to tell if condensor is clogged and how to tell if compressor is on its way out. Compressor still works I think pretty good but cant get vent temps as cold as before about 50 when outside its about 85 befir it was in the fourtys late afternoon 100 plus outside vent temps are about 60 spray a little water on the condensor and the temps come down 6 t0 8 degrees somethings wrong . I have changed the accumulater and orifice tube and vacuumed and recharged the system to get this good. Help!!!!
Aug 20, 2010 at 4:10 AM
MERLIN2021
  • 17,250 POSTS
Are the condenser fins clear of bugs and grime? Try using a blow gun and compressed air to clean the condenser out, then check the radiator cooling fan for proper operation. If it's electric, a high speed fan should start with the A/C compressor, if it's a clutch fan, it could be weak by now. Checking for blockage, the best way is by blowing through it!
Aug 20, 2010 at 4:19 AM
