1994 Chevy S-10 Clutch not engaging fully
DALIXIN
  • 1994 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • MANUAL
  • 246,000 MILES
I have a fairly new clutch on my S-10 (less than a year old) and I'm now having a problem with the clutch fully engaging. When I press the clutch to the floor it seems like it only partially engages and I have to somewhat force the transmission into gear.
This only happens after the truck has been runnin for a while. When the truck is hot.
Also, after stopping with the clutch engaged, the truck moves slightly and it feels like clutch is right at the engage/disengage point.
Is there a clutch adjustment I can make? Do I need to see a mechanic?
Tuesday, October 12th, 2010 AT 3:18 PM
SATURNTECH9
  • 30,869 POSTS
It sound's like your clutch isn't fully releasing when you push the pedal to the floor you say it happens when it's hot it sound's like a pressure plate issue. But you could also have a problem with your clutch master or slave cylinder.I would go get it check out before you damage your transmission.
Tuesday, October 12th, 2010 AT 3:32 PM
