1994 Chevy S-10 Clutch Master Cylinder
113,000 MILES • 6 CYL • 4WD • MANUAL
SPEEDKILLZ
1994 Chevy S10, i recently bought it with 113 thousand clicks on it. put about two thousand clicks on it, then suddenly while driving, the clutch became unresponsive and it wouldnt not come out of gear. theres a hissing coming from the pedal area/ master cylinder when i press it down. I replaced both the clutch master, clutch slave, and bled the lines. the clutch will respond for a few presses, then will promptly return to being unresponsive. Any help is appreciated!
Nov 5, 2010 at 8:47 AM
HMAC300
  • 48,601 POSTS
in caseslike these the clutch has to be checked out before anything else. you could have a bad clutch fork that is worn down and not letting it operate properly or your throwout bearing may be going trough the pressure plate. the sound you hear is probably just the fluid moving and not much to worry about.
Nov 5, 2010 at 10:31 AM
