1994 Chevy S-10 clutch
15,000 MILES • 4 CYL • 2WD • MANUAL
SONNY439
can, and or how do you adjust the clutch, it's catching at the top, and at times will slip?
Sonny
Jun 23, 2008 at 12:24 AM
DOCFIXIT
  • 18,828 POSTS
No adj. it is hydraulic you can check the master cylinder fluid but pedal up and slipping you going to need it replaced.
Hope this helps
Jun 23, 2008 at 12:57 AM
