Other Category problem
1994 Chevy S-10 V6 Four Wheel Drive Manual 150,00 miles
the truck has a small jerky motion when driving normally, but under load (up hill) expecially in 5th gear, it cuts out for a second like the fuel is stopped to the jets in the throttle body (like a hic-op), and it doesn't have the power it should have with this 4.3 engine due to the jerky feeling. It also happens when taking off in a lower gear, but not quite as bad but that is probably from not being so dramatic as higher speeds.
Dec 2, 2007 at 12:08 AM
