1994 Chevy S-10 1994 s10 fuel pump runs after engine turned
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
MSMITH645
could it possibly be the fuel pump relay? if so where is it at? or do i need to replace the fuel pump altogether? when i shut off the key the fuel pump is still running. the only way to shut off the fuel pump is if i pull the fuse for it.
Oct 5, 2010 at 8:00 AM
  • 75,988 POSTS
See below
https://images.2carpros.com/forum/automotive_pictures/12900_fpr_30.jpg
Oct 5, 2010 at 8:04 AM
