1994 Chevy S-10
1994 CHEVROLET S-10
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAM7Z
My engine is still running hot. I had my mechanic replace the radiator and water pump yesterday as well as the thermostat and serpentine belt. It's still running around 230-240 where it should be running around 190. I also don't think it's a blown or leaking head gasket since there is no water in my oil. I also replaced lower radiator hose a few months ago and the upper one is in good condition. Nothing is leaking and the levels in the radiator and reserve tank stays the same. I'm running out of options. Any ideas?
Sep 23, 2010 at 8:01 AM
Could be airlock try bleeding it-don't work block and pressure test it-
Sep 23, 2010 at 9:51 AM
