[quote:661c040d9f="BIGBLUE"]1993 Chevy S-10 6 cyl Four Wheel Drive Automatic 150000 miles
If the timing belt was bad would my truck start[/quote:661c040d9f]
Your truck won't start if Belt Broke or Jumped Timing. However, you vehicle has a chain not a belt. So, if it jumped timing it won't start and it would backfire.
Have you check to make sure you have fuel getting to the injectors and spark to the plugs?
Also check the Cap and Rotor. When was the last Tune Up?
Jul 3, 2008 at 2:25 PM
