1993 Chevy S-10 starts but won't stay running
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
WEALTH67
My S 10 will start for about 15 seconds. I have check the fuel pump, 9 psi. I have checked the fuel filter and it is fine.
Dec 29, 2007 at 12:39 AM
  • 75,988 POSTS
Check engine light is it On or has flashed?
Check the coolant temperature sensor,idle air control valve, throttle position sensor and EGR-
Dec 29, 2007 at 4:32 AM
GTOWNKAYLEE
i don't know if the 93's had passlock, but if it does check the fuses on the fender well under the hood. I had a 98 do the same thing and it was the fuse.
Dec 30, 2007 at 3:33 AM
