1993 Chevy S-10 starting problem
CHANCE7
  • 1993 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 116,000 MILES
My blazer won't start without putting foot on gas unless it was shutoff in the last 5min. New fuelpump, filter, plugs, cap, rotor, runs fine when you get it started thanks for the help
Friday, February 6th, 2009 AT 9:56 AM
JDL
  • 16,098 POSTS
Hello, Did you ever check fuel pressure? Do you have the spider fuel system? They are noted for problems, pressure is critical and the poppets cause problems. I don't know if injector cleaner will help or not? If it is a fuel problem.
Are there any trouble-codes?
Friday, February 6th, 2009 AT 2:35 PM
