1993 Chevy S-10 runs ok then blows black smoke etc.
1993 CHEVROLET S-10
148,000 MILES • 6 CYL • 4WD • MANUAL
CLARENCE ANDERSON
it will stumble and die then will restart in clear flood mode! it has a dtc 15 and has put a dtc14(14 is high temp.and 15 is low temp.) . the dtc 15 is very concistent.I checked the temp. sensor and it shows 5 volts when unplugged and the resistance is 400 ohms warm and 4.4k cool! I added two bottles of gas dryer at first ,thinking I had bad fuel!
thank you
Jul 16, 2008 at 2:22 PM
MMPRINCE4000
  • 8,548 POSTS
Best thing to do is to hook it up to a scan tool to see what the ECM is reading. Low temp should be about -40 degrees. The ECM is seeing a sensor failure and substituting a default value.
Check the wiring to the CLT sensor and I would change it. If the sensor and wiring are good, it may be a bad ECM.
Jul 17, 2008 at 10:14 PM
