1993 Chevy S-10 not getting spark
CPT87GN
  • 8 POSTS
Electrical problem
1993 Chevy S-10 6 cyl Automatic 88000 miles
my truck turns on fine that after i use it a little and turn it off it wont start back up . the cap a rotor were bad weeks ago i replaced worked fine than i started having this problem i replaced the alternator because of the voltage regulator not that .replaced the ignition coil not that replaced the fuel relay not that i checked for spark at the plug and im not getting any what else should i check and how i have a multi meter
Oct 27, 2009 at 10:08 AM
  • 75,988 POSTS
Hi cpt87gn and TY for the donation
Still no spark-check and test the distributor pick-up coil and its air gap, also the ignition control module. Double check the rotor and cap contacts
Oct 27, 2009 at 11:24 AM
