1993 Chevy S-10 No fuel
174,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRILIS80
I have a 93 S-10 and it's getting no fuel to the throttle body.I changed the filter,and the injectors are getting current to the "B" side but not the "A".If you turn the key on, you can hear the fuel pump come on.Where do I go from here?
Apr 25, 2010 at 1:10 PM
BMRFIXIT
  • 19,053 POSTS
Check for codes
Check TPS volts
Computer supply the ground to the injectors
check wiring harness
Apr 25, 2010 at 2:39 PM
