1993 Chevy S-10 Low voltage to injectors
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS1975
My 1993 S-10 4.3l V6 has been acting up the past few weeks by dieing when coming to a stop, It has gotten worse to even sitting in the driveway while warming up.
Sometimes it will not restart for a few minutes like its vapor locking, Other times will restart first try.
I did replace the fuel pump, Fuel Filter and fuel pump relay today, After doing this I still had the same problems.
I had my Brother come over so I could try and catch it from the engine side to see if it was spraying fuel during its mood, While it does this the injectors aren't spraying any fuel.
I then took a complete throttle body that a friend had from a same year 4.3 and installed it with the same results, I then while restarting and shutting off caught it not spraying fuel and checked the voltage dropping down to 5 and 7 volts while cranking it over.
I've checked grounds and wiring harness under the hood with no luck of finding anything wrong.
Any ideas or help would be great.
Thanks Chris B
Feb 6, 2009 at 12:23 PM
DOCFIXIT
  • 18,828 POSTS
ECM drives injector so lack of voltage would be a fault of ECM
Feb 7, 2009 at 4:46 AM
EDDIE S-10
  • 11 POSTS
this sounds pritty much like what mine is doing or how it started run a lil while and shut off my injecters stop spraying to it just dies dont try to stay running or anything mine started doin this when it got cold out so i was kinda thinking its the weather but its just really frustrating dealing with this let me know if u figure anything out with this at all and ill do the same for u u tested the same stuff as me but i dont have a amp meter so i cant test anything like that
Feb 7, 2009 at 5:44 AM
CHRIS1975
I found another ECU local and will pick it up on Monday and hope for the best :lol:
Thanks for the help thus far :D
Feb 7, 2009 at 10:12 AM
DOCFIXIT
  • 18,828 POSTS
Let me know Eddie needs help
Feb 9, 2009 at 8:24 AM
