1993 Chevy S-10 Insturmunt Panell
1993 CHEVROLET S-10
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLAZEROWNER
  • 10 POSTS
Please Help!! All gauges and warning light does not work and my battery is not being charge this is what I have done so far First I took the alternator to an advance auto, it passed all test. Then I put it back on, put the test light on the lug I got a light. Ok then I tested the pigtail connector got no light. Tested insturment panel fuse no light on both sides. Then I took the fuse out tested the circuit no light on both sides. Visusal checking of the fuse shows no break. Check all fuses on both sides and I get a light with the exception of the insturment panel fuse and the silver metalic circuit breaker fuses
Sep 21, 2009 at 4:00 AM
BLAZEROWNER
  • 10 POSTS
[quote:0de06d9975="blazerowner"]Electrical problem
1993 Chevy S-10 6 cyl Four Wheel Drive Automatic 170000 miles
Please Help!! All gauges and warning light does not work and my battery is not being charge this is what I have done so far First I took the alternator to an advance auto, it passed all test. Then I put it back on, put the test light on the lug I got a light. Ok then I tested the pigtail connector got no light. Tested insturment panel fuse no light on both sides. Then I took the fuse out tested the circuit no light on both sides. Visusal checking of the fuse shows no break. Check all fuses on both sides and I get a light with the exception of the insturment panel fuse and the silver metalic circuit breaker fuses[/quote:0de06d9975] Ok re-checked inst/gau fuse and it was blown, change it now it keeps blowing. so I was told it was the ignition switch I started a new thread to adress that problem
Sep 29, 2009 at 8:29 AM
