HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine
Cylinder Head
SPONSORED LINKS
1993 Chevy S-10 heads
NINO90
MEMBER
1993 CHEVROLET S-10
Engine Mechanical problem
1993 Chevy S-10 6 cyl Two Wheel Drive 260000 miles
how to fix water leaking in to the engine, I think it is the heads but dont know where to start looking
Monday, March 17th, 2008 AT 11:43 PM
BLACKOP555
MECHANIC
You should start with a cylinder compression test on all cylinders.
If they are all good chances are its not head or head gasket related and is in turn intake manifold related.
SPONSORED LINKS
Thursday, March 20th, 2008 AT 8:55 AM
Please
login
or
register
to post a reply.
Related Cylinder Head Content
1997 Chevy S-10 Coolant In Engine, Either Bad Gasket...
My 1997 Chevrolet S10 Pickup With 2.2l Engine Recently Had Engine Problems. The Repair People Said That Coolant Shot Out Of The Spark Plug #...
Asked by
cozmo1221
1997
CHEVROLET S-10
VIDEO
Blown Head Gasket Test Video
Instructional repair video
GUIDE
Cylinder Head Gasket Replacement
A cylinder head gasket is used to seal the combustion charge between the cylinder head the engine block, this gasket also controls the flow of coolant between the two as...
1993 Chevy S-10 Timing Belt
If The Timing Belt Was Bad Would My Truck Start
Asked by
BIGBLUE
1993
CHEVROLET S-10
Truck Wont Stay Running
Ok I Bought A 93 S10. Put A 350 In It From A 1990k5 The Truck Ran Fine No Problems. Then All Of A Sudden It Did Not Want To Go Past 3000...
Asked by
daddydec21
1993
CHEVROLET S-10
1993 Chevy S-10 Fuel Problems
S10 2.8 Tpi When You Hook Up A Map Sensor It Loads Up And Quits Its A Brand New Sensor When You Unhook The Map Sensor It Runs A Little...
Asked by
GEORGE ANDERSON
1 ANSWER
1993
CHEVROLET S-10
Where Are The Engine Bolts Located?
Trying To Lift Engine To Make Accessible The Starter
Asked by
rawr
1993
CHEVROLET S-10
VIEW MORE
SPONSORED LINKS
Cylinder Head and Oil System Install Ford
How to Build a Ford 302 Small Block - Part 6:
Taking the Cylinder Heads Off!
Online car repair manuals
