1993 Chevy S-10 Fuel Pump
1993 CHEVROLET S-10
166,000 MILES • 6 CYL • 2WD • MANUAL
TOMMATHEWS
93 Chev S-10 p/up was diagnosed with bad fuel pump...replaced pump, no go. Fuel Pump 15 amp fuse has blown...disconnected oil sensor...no other shorts anywhere. Keeps blowing fuse. Perhaps ECM is bad...causing blown fuse??? Where is ECM located? Will try disconnesting the ESM to see if fuse still blows?
May 6, 2008 at 1:02 PM
BMRFIXIT
  • 19,053 POSTS
Recheck the fuel pump and its wiring harness
May 6, 2008 at 1:33 PM
