1993 Chevy S-10 fuel injectors
1993 CHEVROLET S-10
207,000 MILES • 6 CYL • 2WD • MANUAL
MKP1312
Engine quit with no pror warning. Replaced module in distributor, fuel pump, fuel filter, and fuel pump relay. Still no fuel to injectors. Is there a fuse for the injectors? Could the oil pressure switch be bad?
Jun 10, 2008 at 10:51 PM
Check the fuel pressure and comeback with the readings
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_54.gif
Jun 11, 2008 at 12:20 AM
MKP1312
Unable to check the pressure. No fuel getting to throttle body.
Jun 11, 2008 at 3:16 AM
Sir,
You need to check the fuel pressure so that we know the fuel pump is actually producing pressure.
Jun 11, 2008 at 8:45 AM
