1993 Chevy S-10 Engine Coolant
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIVERUP158
I recently purchased a S-10 pickup truck. I have found that the radiator is realitively new along with a new thermostat and waterpump. (cracked or warped head, headgasket blown from overheating?) I noticed that I was loosing a small amount of coolant and was gettting a small amount of steam from the tailpipe appearing to be from burning antifreeze. I pullled the spark plugs and found that one of the plugs appears to be "wet" while the others are normal. If i modify the radiator cap not to pressurize, will this slow coolant from entering the cylinder and prolong the engine life? With the high milage, coolant problem and also needing a rear main seal would replacing or repairing the engine be the best way to go?
Jan 3, 2008 at 2:35 PM
  • 31,937 POSTS
Hi there,
if you modify the radiator cap from holding pressure, you will only increase your problems, The radiator cap is designed to hold pressure because a liquid under pressure boils at a higher temperature, so your coolant under pressure will not boil at 100Deg C (sorry i work in metric) most cooling systems run at around 85-94 Deg C so with a pressurised system the margin for overheating is increased. As for the other repairs , i would do them sooner rather than later, as you may find the cost nay blow out as things deteriorate further.
Mark (mhpautos)
Jan 3, 2008 at 8:46 PM
