1993 Chevy S-10 emc location
1993 CHEVROLET S-10
SLYHUNTER20002
Engine Mechanical problem
1993 Chevy S-10 6 cyl Four Wheel Drive Automatic 162.00 miles
im trying to find my ecm box so i can change it, im have pree ingnition at start up.iIm wound3ering if i have to keep the same chip when i change it
Sep 10, 2008 at 3:27 PM
Your ECM is located on the right side of the dash
Sep 10, 2008 at 3:39 PM
SLYHUNTER20002
Tank you for the reply,But is it located under or behind the glove box ,Also do i have to keep the same chip or just get a new one.
THAX FOR GETTING BACK SO QUICK.
SLYHUNTER20002@YAHOO.COM
Sep 10, 2008 at 5:26 PM
What's wrong with your vehicle?
Sep 11, 2008 at 6:16 AM
SLYHUNTER20002
WHEN I START MY TRUCK, AND ITS COLD IT TAKES A ALOT OF CRANKING .WHEN WARM IT SEEMS TO STAT RIGHT UP.I HAVE A CODE READER.AND IT SAYS ITS MY ECM THAT NEEDS TO BE CHANGED.
OR I MIGHT BE WRONG,I JUST HAD PLUGS ,WIRES AND CAP AND ROTOR REPLACED,FUEL PUMP IS NEW AND SENDING UNIT IS NEW.IT JUST SEEM VERY SLUGGISH WHEN I PUSH THE GAS PEDAL TO GO.AT 65 IT RUN LIKE A CHAMP.
IT JUST SEEM LIKE IT ISNT GETTING THE RIGHT FUEL NAD AIR MIXTER.
THX STEVE slyhunter20002@yahoo.com
Sep 11, 2008 at 12:43 PM
SWILLIAMS
  • 597 POSTS
ECM is located behind the glove box. Pull the door and the glove box itself and the ECM unbolts from the firewall. If it is actually the ECM you will want to keep the PROM chip in the one you have. Unless you get a replacement programmed to match your vehicle and options. Your problem sounds more like a bad connection than a bad ECM.
Sep 16, 2008 at 10:50 AM
