1993 Chevy S-10 Chevy s10 Dash Light Problem
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
TALKS2MUCH9753
When I go to turn on my lights, my dash light does not light up and also my tail lights do not light up. When used for braking and turning, the tail lights work like they should. But once the turn signal goes off, or I let up off my brakes, they go back to not working. They both worked when I orginally purchased the vehicle so I believe the probelm is connected. Please advise me on what I should do to alleviate the problem because I cannot drive it at night in its current condition.
Thanks!
Aug 13, 2009 at 3:23 AM
JDL
  • 16,098 POSTS
Hello, I'd check the tail-lamps fuse in the fuse box. Double filament bulb at the rear, your turn and brake lites work on one bulb filament, the tail lites work on the other.
Aug 13, 2009 at 3:58 AM
