1993 Chevy S-10 brake and tail lights
144,000 MILES • 6 CYL • 2WD • MANUAL
HANGMAN
  • 8 POSTS
I just got a 93 chevy s-10 I put new bulbs in everything but I don't have any brake lights or tail lights in back. Turn signals work and so does front park lights fuse looked good but I replaced it any way any ideas?
Oct 27, 2008 at 11:54 AM
MASTERTECHTIM
  • 4,750 POSTS
no turn signals in rear, no brake lights in rear and no running lights at all in rear? check the connector under drivers rear frame rail and see if it cam unconnected and also on drivers front frame rail there is a connector under brake booster , check to make sure thats not disconnected
Oct 27, 2008 at 12:03 PM
HANGMAN
  • 8 POSTS
checked all connectors they are all pluged in. any other ideas?
Oct 28, 2008 at 10:36 AM
MASTERTECHTIM
  • 4,750 POSTS
you will need to use a test light and find the connector where the problem lies. a test light will help eliminate unneccessary wire tracing. first start at the wiring at the bulk head. the running light will be brown and turn willo be yellow and green. im fairly confident you will find a connector issue due to the fact that so many lights are out. did you check the ground at the rear yet? make sure its good
Oct 28, 2008 at 11:03 AM
HANGMAN
  • 8 POSTS
thanks for the help wires chewed in to by rat everything fixed thanks
Oct 31, 2008 at 7:25 AM
