I am getting the check engine light comming on intermitently. I bought an actron cp9001 and got code 35, the IAC. I replaced it and reset the computer but still get the light comming on.
Are there other definitions for code 35 using that scanner? And what would be some other possible fixes?
little info about this, it doesn't do this right away. i have to get it up to runnning temp. , then if i goto a drive up atm or get a long red light the light comes on but goes off withing seconds of getting going. also i have seen if i drop it to neutral when the light comes on and pump the gas afor a bit the light goes out.
so i am unsure if it is overheating or if it is with air intake
Apr 25, 2009 at 10:53 AM
