1993 Chevy S-10 actron codes
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
STARBL4107
I am getting the check engine light comming on intermitently. I bought an actron cp9001 and got code 35, the IAC. I replaced it and reset the computer but still get the light comming on.
Are there other definitions for code 35 using that scanner? And what would be some other possible fixes?
little info about this, it doesn't do this right away. i have to get it up to runnning temp. , then if i goto a drive up atm or get a long red light the light comes on but goes off withing seconds of getting going. also i have seen if i drop it to neutral when the light comes on and pump the gas afor a bit the light goes out.
so i am unsure if it is overheating or if it is with air intake
Apr 25, 2009 at 10:53 AM
JNOVACK
  • 723 POSTS
One tip on the Idle Air system on GM's - some need to have a special reset on that part to clear the code. On the 1980-1990's GM's the procedure was to drive the car at a speed exceeding 50 mph for a minimum of five minutes, continuous. You will need to make sure the car stays above 50 for the full five minutes. Make sure to find a nice stretch of open highway where the legal speed will let you do this. This will cause the computer to push the idle air system wide open, then fully closed, to check it over the whole range. After this you can clear the codes and the code should not come back.
If it does, cleaning of the intake may help, since dirt in the passages can affect this system also.
Apr 30, 2009 at 4:57 AM
STARBL4107
thank you for the reply, i took my truck on the interstate this past weekend for the reset and it didn't work. i will check the intake this weekend.
i was wondering if you think the o2 sensor or the erg valve could be causing this?
Apr 30, 2009 at 5:51 AM
JNOVACK
  • 723 POSTS
depending on which V-6 you have that code 35 could also be the Throttle Position Sensor I would also check that
May 1, 2009 at 4:35 AM
