1993 Chevy S-10 ABS Pump
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMAILPJP
My ABS pump is making a humming sound and continues to make it once I turn the car off. I have to disconnect the battery because it will drain it. What can it be and can I do away with the entire abs function as opposed to replacing it if I have to?
Aug 10, 2010 at 2:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is the ABS light on ? the pump is probably shot or maybe just a stuck relay.
Aug 10, 2010 at 3:20 PM
