1993 Chevy S-10
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
TS04978
93 s10 bllazer 4 door had no start condition- found bare wire to fuel injector harness, grounded to intake manifold. fixed that now it starts but acts like fuel line is being pinched off and then let off. it surges at anything above idle, can not get it to drive above 25 mph. Can this be a fuel regulation problem? have checked fuel pressure @ 62psi CMFI ohms resitance is .22
Aug 1, 2009 at 10:59 AM
SERVICE WRITER
  • 9,123 POSTS
Not sure which 4.3 you have, so here are the specs.
https://images.2carpros.com/forum/automotive_pictures/30961_as10_1.jpg
Fuel regulator failures are noted by the pressure being too high, so it may be related. Are there any other symptoms or codes?
Aug 1, 2009 at 11:12 PM
