how do I get my bed off so I can get to the fuel pump I replace the fuel pump but a cord is not on. And I dont want to take it all down again and its a 1993 s10
Thursday, October 28th, 2010 AT 10:36 AM
WRENCHTECH
MECHANIC
There are 4 body bolts on each side holding the bed on. There is a wiring plug in the left rear and remove the screws from the filler pipe.
When I do that I leave the bolts on the passenger side loose but still there and then tilt it from the driver's side. Just make sure you have something as a safety to prevent the bed from falling on you.
