1993 Chevy S-10
150,000 MILES • 6 CYL • 2WD • MANUAL
LORIEBURCH
drove through water. truck stalled, then cranked but will only get up to 20 mph.
Oct 12, 2009 at 1:55 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd check for codes. Maybe give you a direction? Maybe a sensor got wet, a fuse or something shorted out?
https://images.2carpros.com/forum/automotive_pictures/170934_aldl_26.jpg
If datalink connector looks like the above picture. Turn the key just to on position, no crank, use jumper wire between A & B terminals, the check engine lite starts flashing, you count the flashes to get the codes.
Oct 12, 2009 at 3:36 AM
