1992 Chevy S-10 Tune-up Specs
TRIKERPHIL
Engine Performance problem
1992 Chevy S-10 6 cyl Two Wheel Drive Manual
I just acquired a trike (3 wheeled motorcycle) custom built from the running gear of a 1992 Chev S-10 2.8L V6 with 4 speed manual transmission. I can't find the tune-up specs (points, spark plug, and timing) settings anywhere.
Can you give me the tune-up specs and part numbers?
May 19, 2009 at 11:16 AM
ZACKMAN
  • 4,202 POSTS
Spark plug: AC Delco R43TSK. Gap 0.45" Spark plug wire: Borg Warner CH7653 Distributor cap: Borg Warner C218 Distributor rotor: Borg Warner D189 Air filter: Fram CA3588 Fuel filter: Fram G3727 PCV valve: Fram FV191 Firing order:
https://images.2carpros.com/forum/automotive_pictures/55316_92s10firing_1.jpg
May 19, 2009 at 12:19 PM
TRIKERPHIL
Thanks for the info, but I didn't find timing setting listed in the specs anywhere and I really need that as well.
I will look forward to your prompt reply.
May 19, 2009 at 4:41 PM
ZACKMAN
  • 4,202 POSTS
Ignition timing: 10 degrees BTDC @ idle @ Neutral. Procedure: 1. Set parking brake, block drive wheels and place transmission in Neutral. Warm engine to normal operating temperature. Turn A/C off (if equipped). Ensure SERVICE ENGINE SOON light is off. 2. Disconnect Tan/Black Electronic Spark Timing (EST) by-pass connector wire, located near heater housing in passenger compartment. On all models, DO NOT disconnect 4-wire connector at distributor. 3. Connect timing light to No. 1 spark plug wire. Check timing and adjust if necessary. Reconnect EST by-pass connector, and clear ECM trouble code. Ignition coil resistance: 500 - 1500 ohms Idle speed: 800 rpm Just in case you need it. Timing marks:
https://images.2carpros.com/forum/automotive_pictures/55316_92s10timing_1.jpg
May 19, 2009 at 5:33 PM
