1992 Chevy S-10 tapping valves
108,000 MILES • 6 CYL • 2WD • MANUAL
JMARSHALL83
how far can i drive with tapping valve
Mar 5, 2009 at 2:32 PM
BLACKOP555
  • 10,386 POSTS
as long as you have proper amount of il in teh crank case, and oil is getting to the valves, you can drive it till the engine finally wears out from old age.
dependso n why its tapping, if its bet or the rocker is torn then you might want to change it asap.
Mar 8, 2009 at 2:37 PM
