1992 Chevy S-10 speedometer doesn't work
CGSHARK5
1992 Chevy S-10 6 cyl Two Wheel Drive Automatic
I recently replaced the transmission myself with a rebuild- not the problem- and the speedometer won't work, so I replaced speed sensor and same result. It shifts just as it should but check engine light does come on. I checked connection on back of instrument panel, good connection. Cruise control doesn't work either. Is it a short in electrical or something else?
Nov 16, 2009 at 12:09 AM
PEAR69
  • 1,482 POSTS
What is the trouble code associated with the check engine light? Is it a digital dash?
Nov 16, 2009 at 5:16 PM
CGSHARK5
Have not got an answer for the trouble code but the dash is not digital
Nov 18, 2009 at 1:31 AM
PEAR69
  • 1,482 POSTS
The trouble code will lead you to the problem.
Nov 18, 2009 at 9:32 AM
