1992 Chevy S-10 slowly losing accessorys
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
LINKABOUTIT
1st to go was the heater blower would go off on it own sometimes but then a passenger door closing would get it going again. That doen't work anymore. Then I noticed then lights for the power rear view mirror no longer worked but the interrior light worked fine. Then I noticed the 4x4 switch wouldn't work. Truck starts and runs fine, sometimes the fuel pump is slow to pump like it needs a second cance to activate when i turn the ignition switch on/off til i hear the fuel pump. I asked around and someone said fusable links and possible negetive lacking. I dunno, but I thought someone here might. Thanks in advance. I have no cash hence I'm doing it myself and still driving a 1992..
Apr 6, 2010 at 6:40 AM
THIS IS MIKE
  • 686 POSTS
You can test the battery cable by pulling on it to see if it is still rigid or if it has some elastic properties like a rubber band. The cable is the fuseable link. Make sure you check all of your fuses to make sure they are good.
Apr 7, 2010 at 8:24 AM
