1992 Chevy S-10 r&r
EL_CLINT_O
Engine Mechanical problem
1992 Chevy S-10 6 cyl Two Wheel Drive Automatic
how do u remove the oil pan
Jan 13, 2009 at 5:49 AM
DE772601
  • 123 POSTS
Hi well to make it easy take the two bolts out of the motor mounts and use a engine hoist to raise the motor just a few inches to allow some extra room to get the oil pan down and out. This will give you a little more room from the cross member and the oil pick up that is inside the pan. I hope this will be of some help to you.
Jan 13, 2009 at 11:55 AM
