1992 Chevy S-10 Oil pressure
217,111 MILES • 6 CYL • 2WD • MANUAL
ATLS10
I have the 4.3 liter Z code engine. On cold starts, the oil pressure display runs up close to the max; after warnmed up it drops nearly to zero at idle...
Jan 6, 2008 at 10:10 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
I would first have the oil pressure tested cold with a master gauge , allow to warm up and check hot idle pressure, this will give you a true indication as to the oil pressure, this may just be a faulty gauge problem, do the test to make sure oil pressure is ok.
Mark (mhpautos)
Jan 6, 2008 at 12:58 PM
