[quote:68f58e9b06="jdl123"]Is this a heated 02 sensor? If there is three wires, one is B+ for the heater circuit, ground, the signal goes to the ecm. I'm not sure which wire your talking about?[/quote:68f58e9b06]
the o2 sensor screws into the manifold and there is one wire coming from the sensor with a connector at the end of the wire and i dont know where it plugs up at. I think it should go somewhere to the main wiring harness but I cannot find where it might plug into.
Apr 9, 2009 at 4:14 AM
