1992 Chevy S-10 gas guzzler
1992 CHEVROLET S-10
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
MUNOZMARTIN76
my 92 chevy s10 4.3L is using to much gas i can go 18 miles and it uses up about 5 dollars worth of gas. I just did a tune up.
Oct 11, 2010 at 10:19 PM
Let's try fuel there's a lot more areas that can reduced fuel economy-could be running rich due to the following
1.Excessive fuel pressure can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors and fuel pressure regulator.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
Oct 12, 2010 at 3:27 AM
