Engine problem
1992 Chevy S-10 Four Wheel Drive Automatic 200002 miles
i have an s10 blazer with a vortec 4.3L that will not start, it had sum bad gas but thats besides the point, ok when i try to start it it will sumtimes stop like it has a thrown rod. if i put it in neutral and push it a few feet it will do it again, but once it gets jamed thats it, just a loud click from the starter. i dont get it tho cuz its an automatic so when i push it its not doing anything to the motor. also i have had to replace the starter because the old one was shatterd. iv checked the batery the new starter and part of the flexplate. is it possible it culd b the transmition jaming up? after it clunks to a stop sum trany fluid leaks out from the torque converter area. i got it to run then it stalled on the bad gas. and now its clicking again.... im tired of pushing it, i cant even run a proper compression test, also the oil looks fair no metal shavings or coolant.... im stumped guys
Jan 21, 2008 at 7:10 PM
