1992 Chevy S-10 clutch
1992 CHEVROLET S-10
STEVENPALASSIS
Transmission problem
1992 Chevy S-10 6 cyl Two Wheel Drive Manual
My truck will not go in to gear when I depress the clutch. This problem began gradually. At first it was just hard to get in to gear (when I did get it to shift it didn't slip out of that gear). I had my clutch replaced about 3 years ago and the problem I'm having now doesn't feel the same (the clutch still feels like it has good pressure, it would stay in gear when I could get it in there and I am not loosing fluid). I've heard that a worn bushing under the shifter might cause this problem, but I'm worried it might be something more complex than this...Where would be a good place to start troubleshooting this problem?
-Thanks!
Aug 2, 2009 at 2:20 PM
DOCFIXIT
  • 18,828 POSTS
Does it go into gears when engine is off? if yes then clutch is not disengaging or input shaft is siezed to pilot bearing.
Aug 3, 2009 at 6:50 AM
