1992 Chevy S-10
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEGCAT
truck will start up and run ,than shut down.sometimes it will run for 5 min. ,2min. or 30 sec.i replaced the idle air control valve and fuel pump is pumping gas. could it be the tps sensor or something else. thank-you.
Jan 28, 2008 at 9:59 AM
BLACKOP555
  • 10,386 POSTS
Will it crank back up after it dies or does it have to sit for a while?
Jan 28, 2008 at 10:44 AM
SEGCAT
[quote:300d4e7447="blackop555"]Will it crank back up after it dies or does it have to sit for a while?[/quote:300d4e7447]
Jan 29, 2008 at 3:30 AM
