Oil Capacity is 4.5 - 5 Quarts depending on Oil Filter
Tranny Fluid is 5 Quarts which does not include the Torque Converter.
Belt Size you can call your local parts store for Part number.
Plug gap will depend on engine size in Liters and the 8th Digit of the VIN Number. You can also get this info from your local parts store.
FYI - The info you are asking for here is readily available from your local parts store also.
SPONSORED LINKS
Thursday, February 11th, 2010 AT 9:29 PM
