1991 Chevy S-10 starting
210,000 MILES • 6 CYL • 4WD • AUTOMATIC
RONHARRIS
After vihicle has been started, run a while, then shut down, it often will not re-start. Starter cranks enthusiastically, but engine won't start. Have replace plugs, plug wires, dist. rotor and cap, fuel pump. No change in result.
Oct 12, 2009 at 7:43 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Ron,
It sound like the Ignition Control Module, it is mounted in or on the side of the distributor.
That is the typical symptom of the control module going bad, it starts failing when it get hot.
Oct 12, 2009 at 11:48 AM
RONHARRIS
Do you mean the ignition module or the ignition control unit?
Oct 12, 2009 at 12:00 PM
OBXAUTOMEDIC
  • 3,711 POSTS
It is called the Ignition Control Module, some call it the control module. It's mounted in the distributor. There are I believe two sets of wires that connect to it. Also the design will depend on the engine size in liters.
Oct 12, 2009 at 12:37 PM
