1991 Chevy S-10 shakes
1991 CHEVROLET S-10
147,000 MILES • 6 CYL • 2WD • MANUAL
DOUGLISA
My s 10 shakes in the front end at low rates of speed and comming to a stop
May 8, 2009 at 1:10 AM
MIKE H R
  • 3,094 POSTS
does this happen just when applying brakes? if so check the discs, to see if there is anything that could have gotten on the discs example some dirt or oil or grease. try using some brake cleaner on the front brakes. if slow speed check the wheel balancing. I would have the front end checked to see if there is anything that needs servicing
May 8, 2009 at 1:27 AM
