1991 Chevy S-10 Oil Pressure
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
TEKIBA
I have a 1991 S-10 4.3 L. During normal driving the oil pressure willl drop to zero and the check gages light will come on. If I turn off the engine for 5 - 7 seconds and restart the enging the oil pressure will return to 35-40 psi and stay there for a while. Is this the oil pump or the oil pressure sensor going bad ??
Apr 26, 2008 at 2:00 PM
BUZZSAW
  • 1,198 POSTS
[quote:835576280f="Tekiba"]Engine Performance problem
1991 Chevy S-10 6 cyl Two Wheel Drive Automatic 160000 miles
I have a 1991 S-10 4.3 L. During normal driving the oil pressure willl drop to zero and the check gages light will come on. If I turn off the engine for 5 - 7 seconds and restart the enging the oil pressure will return to 35-40 psi and stay there for a while. Is this the oil pump or the oil pressure sensor going bad ??[/quote:835576280f]
I would try it its not expensive, is that the only guage that drops off? been looking at wiring digrams
Apr 26, 2008 at 2:17 PM
