1991 Chevy S-10 leaks
CHEVYRUNNER91
  • 6 POSTS
Interior problem
1991 Chevy S-10 6 cyl Two Wheel Drive Manual
i have a 91 chevy s10 pick-up. whenever it rains heavily, i notice the carpet on the driver side is wet. the weather stripping around the door and the moon roof are in good condition. i followed the leak and it goes towards the left side of the firewall. there are no holes, no areas that are rusted out inside the cab. any suggestions?
Mar 29, 2009 at 6:50 AM
ROB M
I had a similar problem. The water in my S-10 was coming from around the electrical block mounted on the firewall under the master cylinder. I cleaned up the area around the electrical block and sealed it with silicone sealant. I also cleaned up the air intake where the wiper linkage is located to ensure that the water from the windshield drained the right way. No problems for five years now.
rob m
Mar 30, 2009 at 3:11 PM
CHEVYRUNNER91
  • 6 POSTS
thanks. ill have to check it out tom.
Apr 1, 2009 at 9:46 AM
