hall effect switch
80,000 MILES • 4 CYL • 2WD • MANUAL
BBKKTT55
Where is the Hall Effect Switch mounted? It is not on the distributor as the book indicates.
Can a defective Hall effect Switch cause the engine not to start?
Thank You
Dec 4, 2008 at 12:39 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:bab16293fa="bbkktt55"]Electrical problem
1991 Chevy S-10 4 cyl Two Wheel Drive Manual 80000 miles
Thank You[/quote:bab16293fa]
Yes, a bad Hall Effect Switch will cause a no start.
What is the 8th Digit of the Vin if it is an A then it doesn't have the Hall Effect Switch, it has a pick-up coil.Similar to a hall effect but it uses magnetic field. Which ever it is it will be in the distributor
Dec 4, 2008 at 12:52 PM
DBLAKE8806
i have a 91 s10 2.5L vin code E the timing is off 4 degrees. my problem is the distributor will not turn. it is froze to the block. i need to know how to fix the problem or if there is another way to fix the timing. thank you
May 4, 2019 at 9:53 AM (Merged)
MERLIN2021
  • 17,250 POSTS
2.5L (VIN E) 1. Set parking brake, block drive wheels and place transmission in Neutral or Park. Warm engine to normal operating temperature. Turn A/C off (if equipped). Ensure SERVICE ENGINE SOON light is off. 2. Connect jumper between ALDL connector terminals "A" and "B". SERVICE ENGINE SOON light should begin flashing. Connect timing light. 3. Note average timing of cylinders No. 1 and 4 and adjust to specification if necessary. See 4- CYLINDER IGNITION TIMING table. Remove jumper from ALDL connector. Ensure SERVICE ENGINE SOON light is off.
https://images.2carpros.com/forum/automotive_pictures/62217_s10_2.jpg
Loosen the hold down bolt, and if needed spray some WD-40 down there and use a wrench on the shaft. Are you checking the timing this way?
