1991 Chevy S-10 Gauges
1991 CHEVROLET S-10
230,000 MILES • 6 CYL • 4WD • AUTOMATIC
J.HOWSON
I have a 91 s10 blazer, recently the ignition broke so we replaced the entire steering column, and apparently a spring popped loose in the replacement and none of my gauges work, speedo, fuel, voltage, oil..etc
occasionally the fuel works but rarely
Jan 13, 2009 at 11:05 AM
DE772601
  • 123 POSTS
Hi well what spring came out and if so if it was the ignition spring where the key goes, you may have another problem in the other column that you installed sounds like a wiring problem.
Jan 13, 2009 at 11:48 AM
