1991 Chevy S-10 drive shaft removal
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
PMOYNAHAN
I have a split drive shaft. I followed the instructions in the chilton manual but I can't remove the drive shaft in order th replace the "U" joints. On single drive shafts the rear joint just drops out. This one won't budge. What's the trick?
Jan 31, 2010 at 7:46 AM
  • 110,248 POSTS
Which end are you having trouble with?
Feb 3, 2010 at 12:19 AM
