1991 Chevy S-10 differential noise or other
332,000 MILES • 6 CYL • 2WD • MANUAL
SYCO4EVER
91' , S10, 2 wheel drive with the 4.3.
when ever i accelerate hard, or pop the clutch a ticking or pining sound occurs. It seems to come from the differential or another area from the rear.
May 8, 2008 at 2:56 PM
  • 31,937 POSTS
Hi there,
Best start with checking the diff oil level, check the unis for wear. If driving and the noise is constant it may be a wheel bearing, if you can get it to change pitch with throttle, it well could be the diff.
mark (mhpautos)
May 8, 2008 at 5:45 PM
