1991 Chevy S-10 Clutch
1991 CHEVROLET S-10
13,821 MILES • 6 CYL • 2WD • MANUAL
RITCHIEDFW
My clutch graduatly started leaking fluid then became more and more. I found the fluid to be leaking where the clutch rod goes through the floor around the rubber seal (I don't know the correct term)[img:ab64f4029e]http://www.2carpros.com/forum/automotive_pictures/321172_clutch3_1.jpg[/img:ab64f4029e]. The clutch often wouldn't engage at all and I would add fluid and pump and pump until it would engage but that's not working now. I've added DOT3 and DOT4 fluid the DOT4 seemed to go through faster.
Feb 21, 2009 at 4:54 AM
DOCFIXIT
  • 18,828 POSTS
Think your in need of a clutch master cylinder and would reccomend the slave also.
Feb 21, 2009 at 6:27 AM
